주요 콘텐츠로 건너뛰기
UP! Plus 2 Spool Holder Replacement
필요한 것
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: 1 단계, 이미지 1개 중 1개
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 3개 중 1개 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 3개 중 2개 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 2 단계, 이미지 3개 중 3개
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 3개 중 1개 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 3개 중 2개 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 3 단계, 이미지 3개 중 3개
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 3개 중 1개 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 3개 중 2개 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 4 단계, 이미지 3개 중 3개
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
valerie boyer
회원 가입일: 10/12/14
508 평판
안내서 4개를 작성함
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 회원
CPSU-MANESS-F14S14G31
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 1,388
