주요 콘텐츠로 건너뛰기
USB Installation Media Creation
필요한 것
  1. USB Installation Media Creation, Download Rufus: 1 단계, 이미지 1/2 USB Installation Media Creation, Download Rufus: 1 단계, 이미지 2/2
    • THIS PROCEDURE WILL ERASE YOUR USB DRIVE! IF POSSIBLE, USE A NEW USB DRIVE.
    • If you are reusing an old drive, format it first!
    • To write the ISO, download Rufus. Place this somewhere it is easily found.
  2. USB Installation Media Creation, Download your ISO: 2 단계, 이미지 1/3 USB Installation Media Creation, Download your ISO: 2 단계, 이미지 2/3 USB Installation Media Creation, Download your ISO: 2 단계, 이미지 3/3
    • Torrent clients require additional configuration NOT COVERED in this guide.
    • After downloading Rufus, download the ISO you want to write to the USB drive.
  3. USB Installation Media Creation, Locate the ISO: 3 단계, 이미지 1/2 USB Installation Media Creation, Locate the ISO: 3 단계, 이미지 2/2
    • Default download location: Windows 7/8.x/10: Downloads
    • Plug the USB drive in and select the ISO you want to use.
  4. USB Installation Media Creation, Writing the ISO file: 4 단계, 이미지 1/3 USB Installation Media Creation, Writing the ISO file: 4 단계, 이미지 2/3 USB Installation Media Creation, Writing the ISO file: 4 단계, 이미지 3/3
    • If your system has a buggy legacy BIOS, click on "Add fixes for older BIOSes".
    • Open Rufus and click SELECT. Find the ISO and click Open.
    • Rufus will ask you to choose ISO or DD mode. If unsure, choose ISO mode.
    • After configuring the writing process, click start. Click OK on the formatting warning.
결승점
다른 13명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,987 평판
안내서 50개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 2개
Unetbootin does not work anymore and is considered unstable to use when installing any Linux OS, also 4GB USB drives are more than big enough to get the job done
Will Unknown - 답글
My reasoning for saying 8GB is because 4GB sticks are all but nonexistent (8GB is more popular now), but if you already own the 4GB stick then it'll work. I even use one from 2006 in the guide, to show that reuse is possible.
Oh really? I always thought it was still a usable option - thanks for letting me know that I was wrong.
Nick -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 60
전체 시간: 3,164
