주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
USB/Auxiliary Port
필요한 것
    1. USB/Auxiliary Port, Outer Case: 1 단계, 이미지 2개 중 1개 USB/Auxiliary Port, Outer Case: 1 단계, 이미지 2개 중 2개
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      댓글 쓰기
    2. USB/Auxiliary Port: 2 단계, 이미지 1개 중 1개
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      댓글 쓰기
    3. USB/Auxiliary Port: 3 단계, 이미지 1개 중 1개
      • Slide out the rubber foot located on the bottom of the case.
      댓글 쓰기
    4. USB/Auxiliary Port: 4 단계, 이미지 1개 중 1개
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      댓글 쓰기
    5. USB/Auxiliary Port: 5 단계, 이미지 3개 중 1개 USB/Auxiliary Port: 5 단계, 이미지 3개 중 2개 USB/Auxiliary Port: 5 단계, 이미지 3개 중 3개
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      댓글 쓰기
    1. USB/Auxiliary Port, USB/Auxiliary Port: 6 단계, 이미지 2개 중 1개 USB/Auxiliary Port, USB/Auxiliary Port: 6 단계, 이미지 2개 중 2개
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      댓글 쓰기
    2. USB/Auxiliary Port: 7 단계, 이미지 1개 중 1개
      • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      댓글 쓰기
    3. USB/Auxiliary Port: 8 단계, 이미지 3개 중 1개 USB/Auxiliary Port: 8 단계, 이미지 3개 중 2개 USB/Auxiliary Port: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      댓글 쓰기
    4. USB/Auxiliary Port: 9 단계, 이미지 1개 중 1개
      • Remove the 5mm T6 screw holding the port assembly onto the end cap.
      • Unlike the flat top screw holding the metal housing, these screws are roundtop.
      댓글 쓰기
    5. USB/Auxiliary Port: 10 단계, 이미지 1개 중 1개
      • Remove the old port assembly from the end cap.
      • Alternate Reassembly required, read on.
      댓글 쓰기
    6. USB/Auxiliary Port: 11 단계, 이미지 1개 중 1개
      • Disconnect the Motherboard connection ribbon from the motherboard.
      • The ribbon should no longer be connected at either end.
      댓글 쓰기
    7. USB/Auxiliary Port: 12 단계, 이미지 1개 중 1개
      • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
      댓글 쓰기
    8. USB/Auxiliary Port: 13 단계, 이미지 1개 중 1개
      • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
      • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
      댓글 쓰기
    9. USB/Auxiliary Port: 14 단계, 이미지 2개 중 1개 USB/Auxiliary Port: 14 단계, 이미지 2개 중 2개
      • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
      • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
      댓글 쓰기
    10. USB/Auxiliary Port: 15 단계, 이미지 2개 중 1개 USB/Auxiliary Port: 15 단계, 이미지 2개 중 2개
      • Reconnect the button ribbon connector on the top of the port assembly.
      댓글 쓰기
    11. USB/Auxiliary Port: 16 단계, 이미지 2개 중 1개 USB/Auxiliary Port: 16 단계, 이미지 2개 중 2개
      • Reconnect the endcap to the plastic housing.
      • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
      댓글 쓰기
    12. USB/Auxiliary Port: 17 단계, 이미지 1개 중 1개
      • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
      • Finish reassembling in descending order starting at step 5.
      댓글 쓰기
결론
To reassemble your device, follow steps 1 through 5 in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Noah Sadler
회원 가입일: 04/01/15
548 평판
안내서 2개를 작성함
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G1
5 회원들
안내서 27개를 작성함
1가이드 댓글
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 61
전체 시간: 15,972
