소개
This guide walks you through the steps to replace the external speaker on your phone. You can follow these same steps to check your speaker connection as well.
필요한 것
Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
거의 끝나갑니다!
결론
