주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UTStarcom XV6700 Motherboard Replacement
필요한 것
    1. UTStarcom XV6700 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Press the on/off button on the top to power the phone off.
      댓글 쓰기
    2. UTStarcom XV6700 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery cover by pressing and sliding the cover down and off of the phone.
      댓글 쓰기
    3. UTStarcom XV6700 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 UTStarcom XV6700 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 UTStarcom XV6700 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Pull the battery removal tab and lift the battery out of the phone.
      • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
      댓글 쓰기
    1. UTStarcom XV6700 Motherboard Replacement, Camera: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
      댓글 쓰기
    2. UTStarcom XV6700 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 UTStarcom XV6700 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Use firm pressure to carefully pry off the cover with your fingers.
      댓글 쓰기
    3. UTStarcom XV6700 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
      댓글 쓰기
    4. UTStarcom XV6700 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Gently pry off the camera flash circuit board with the spudger.
      댓글 쓰기
    5. UTStarcom XV6700 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Gently pry off the camera with the spudger.
      댓글 쓰기
    1. UTStarcom XV6700 Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
      • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
      댓글 쓰기
    2. UTStarcom XV6700 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 4.0-mm #00 Phillips screw that holds the antenna in place. The antenna does not need to be removed.
      댓글 쓰기
    3. UTStarcom XV6700 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 UTStarcom XV6700 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 UTStarcom XV6700 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
      • Use the spudger or plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
      • Carefully pry the black portion of the case away from the silver portion.
      • Do not try to remove the case completely. The speaker wire is still connected to the motherboard.
      댓글 쓰기
    4. UTStarcom XV6700 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, pull with gentle pressure in the direction of the wire to unplug from the motherboard connector.
      댓글 쓰기
    5. UTStarcom XV6700 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the 4.0-mm #00 Phillips screw holding the motherboard in place. The screw is in the middle of the motherboard, near the outside edge.
      댓글 쓰기
    6. UTStarcom XV6700 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 UTStarcom XV6700 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
      • With your fingers, disconnect the keyboard cable from the motherboard. The cable is orange with the letters T/B printed on the connector.
      댓글 쓰기
    7. UTStarcom XV6700 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 UTStarcom XV6700 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
      • Carefully lift up on the motherboard with the spudger until you can see the display cable connected to the underside of the motherboard. The display cable connector will be taped over.
      댓글 쓰기
    8. UTStarcom XV6700 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
      • Use the spudger to peel away the tape from the connector.
      댓글 쓰기
    9. UTStarcom XV6700 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
      • Using the spudger, pry away the display cable connector from the motherboard. The motherboard is now completely disconnected.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jesse Walker
회원 가입일: 06/04/13
201 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 731
