주요 콘텐츠로 건너뛰기
Ubuntu Linux Fixing Crackling/Glitching Audio
  1. Ubuntu Linux Fixing Crackling/Glitching Audio, Ubuntu Linux Fixing Crackling/Glitching Audio: 1 단계, 이미지 1개 중 1개
    • Open your terminal and type sudo nano /usr/share/pipewire/pipewire-pulse.conf
    • Press enter. If you are prompted for your password, enter your device's password and press enter.
    • You now have access to your pipewire settings!
  2. Ubuntu Linux Fixing Crackling/Glitching Audio: 2 단계, 이미지 1개 중 1개
    • Press Ctrl + W to search for pulse.min.quantum and press Enter.
    • You should find a line that says #pulse.min.quantum = 128/48000 # 2.7ms
    • Remove the first '#' at the beginning of the line and change the number 128 to 256.
    • To save your new settings, press Ctrl + X, then Y, then Enter.
  3. Ubuntu Linux Fixing Crackling/Glitching Audio: 3 단계, 이미지 1개 중 1개
    • Test your new settings to see if the crackling continues.
    • If the crackling is gone, great! If not, repeat the previous step but change the number 256 to 512. Then test again.
결론
If you'd like to reverse the changes made in this guide, go through the steps again but change the new number to 128 and add a '#' back on the beginning of the line.
작성자
1다른 기여자 명과 함께
Lynx
회원 가입일: 01/04/25
639 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 104
지난 30일: 359
전체 시간: 965
