주요 콘텐츠로 건너뛰기
Udi Discovery U818A FPV Camera Replacement
필요한 것
  1. Udi Discovery U818A FPV Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Place the drone on its back, with the runners facing upward.
    • Using the Phillips #00 screwdriver, unscrew the single 2mm screw located on the drone body which connects the headlamp and wiring to the center of the drone frame.
  2. Udi Discovery U818A FPV Camera Replacement: 2 단계, 이미지 1/1
    • Grasp one of the propeller arms with the fingers of one hand while holding the drone frame with the other hand.
    • Firmly pull the propeller arm upward to separate it from the drone body.
    • Repeat this process to remove the three other propeller arms.
  3. Udi Discovery U818A FPV Camera Replacement: 3 단계, 이미지 1/1
    • Carefully remove the drone body from the frame.
  4. Udi Discovery U818A FPV Camera Replacement: 4 단계, 이미지 1/2 Udi Discovery U818A FPV Camera Replacement: 4 단계, 이미지 2/2
    • Flip the drone body onto the runners so the wires and motherboard are facing upward.
    • Disconnect the black and blue camera wires from the motherboard.
    • You may need to use a pointed metal pick to loosen the red putty that holds the connectors together.
  5. Udi Discovery U818A FPV Camera Replacement: 5 단계, 이미지 1/1
    • Be careful when separating the camera away from the runners and drone body—the plastic is brittle and may snap, causing injury to the hand.
    • Pry the camera away from the main drone body.
    • Use a spudger for extra leverage if the parts do not easily separate.
결론
Debra Crawford
회원 가입일: 10/11/18
401 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 292
