소개
Is your drone propeller not functioning correctly? This guide will show you how to replace a damaged propeller blade on your Udi Discovery U818A FPV drone. You will need a Phillips head screwdriver size PH00 to complete this task.
필요한 것
Using the size PH00 Phillips screwdriver head, remove the 2mm screw from the base of the propeller blade.
거의 끝나갑니다!
결론
