소개
This guide will show users how to fix the stretcher of an umbrella by using a thin piece of copper wire in place of where the rivet once was.
URL for half-hitch knot:
필요한 것
다른 6명이 해당 안내서를 완성하였습니다.
댓글 7개
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
19 months and still holding :)
Lou -
it might work for some for a temp fix But I tried this and it will not work.
it will bind and it will not close like it is supposed to
