소개
A really windy day can break an umbrella. In some cases, a joint will break, disconnecting the stretcher from the rib. You will be using a needle and thread in order to replicate the function of the joint that held the stretcher and the rib together. In addition, this guide will also cover how to sew a small rip on the canopy.
필요한 것
Take the broken part of the stretcher to rib joint.
Realign it with the rib assembly.
The umbrella is fixed now, you may now use the umbrella freely.
다른 2명이 해당 안내서를 완성하였습니다.
