주요 콘텐츠로 건너뛰기
Umbrella Stretcher to Rib Joint Repair
필요한 것
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 1 단계, 이미지 1/2 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 1 단계, 이미지 2/2
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: 2 단계, 이미지 1/1
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: 3 단계, 이미지 1/1
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: 4 단계, 이미지 1/1
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: 5 단계, 이미지 1/2 Umbrella Stretcher to Rib Joint Repair: 5 단계, 이미지 2/2
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: 6 단계, 이미지 1/2 Umbrella Stretcher to Rib Joint Repair: 6 단계, 이미지 2/2
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: 7 단계, 이미지 1/3 Umbrella Stretcher to Rib Joint Repair: 7 단계, 이미지 2/3 Umbrella Stretcher to Rib Joint Repair: 7 단계, 이미지 3/3
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
결론
The umbrella is fixed now, you may now use the umbrella freely.
다른 2명이 해당 안내서를 완성하였습니다.
Rodrigo Soliva
회원 가입일: 10/26/17
182 평판
안내서 1개 작성함
DePaul University, Team S1-G8, Dush Fall 2017 DePaul University, Team S1-G8, Dush Fall 2017 회원
DPU-DUSH-F17S1G8
2 회원들
안내서 1개 작성하였습니다
댓글 2개
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - 답글
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 36
30일 전: 199
전체 시간: 12,077
