주요 콘텐츠로 건너뛰기
Unbranded UB-15MS10 Back Camera Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Back Camera Replacement: 2 단계, 이미지 1/1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Back Camera Replacement: 3 단계, 이미지 1/2 Unbranded UB-15MS10 Back Camera Replacement: 3 단계, 이미지 2/2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Back Camera Replacement: 4 단계, 이미지 1/1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Back Camera Replacement: 5 단계, 이미지 1/1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: 6 단계, 이미지 1/1
    • Remove the small piece of black tape.
  7. Unbranded UB-15MS10 Back Camera Replacement: 7 단계, 이미지 1/1
    • Remove the black 4-mm #0 screw.
  8. Unbranded UB-15MS10 Back Camera Replacement: 8 단계, 이미지 1/1
    • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
    • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jordan Turk
회원 가입일: 09/21/15
331 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-1, Baechle Fall 2015 IUPUI, Team 2-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 712
