주요 콘텐츠로 건너뛰기
Unbranded UB-15MS10 Screen Replacement
필요한 것
  1. Unbranded UB-15MS10 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Screen Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 Screwdriver to unscrew the two 1.2mm screws within the compartment. This allows the device to be opened.
  3. Unbranded UB-15MS10 Screen Replacement: 3 단계, 이미지 1/2 Unbranded UB-15MS10 Screen Replacement: 3 단계, 이미지 2/2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Screen Replacement: 4 단계, 이미지 1/1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Screen Replacement: 5 단계, 이미지 1/1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Screen Replacement: 6 단계, 이미지 1/1
    • Unscrew the five 1.2mm screws that connect the circuit board to the device.
  7. Unbranded UB-15MS10 Screen Replacement: 7 단계, 이미지 1/1
    • There are three silver tabs around the internal components that connect it to the frame with screws. Unscrew these screws to remove the internal components.
  8. Unbranded UB-15MS10 Screen Replacement: 8 단계, 이미지 1/1
    • Carefully lift the internal components from the screen and place them into a replacement screen.
결론
To reassemble your device, follow instructions 1-7 in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Evan Peterson
회원 가입일: 03/08/17
320 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G5
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
All the instruction are fine to follow except the last one, step 8. What tool to use to lift the internal components from the screen frame or where to start to lift without damage to the internal components?
Alfred H. Schaefer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 12
전체 시간: 1,904
