주요 콘텐츠로 건너뛰기
Unbranded UB-15MS10 Speaker Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Unbranded UB-15MS10 Speaker Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Speaker Replacement: 3 단계, 이미지 2개 중 1개 Unbranded UB-15MS10 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Speaker Replacement, Speaker: 6 단계, 이미지 1개 중 1개
    • Remove the yellow tape from the speaker.
  7. Unbranded UB-15MS10 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 4-mm #0 screws holding the speaker in place.
    • The copper-colored plastic piece covering the speaker does not need to be removed from the device, move it to the side to reach the screws.
  8. Unbranded UB-15MS10 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the silver tape covering the speaker's black and red wires.
  9. Unbranded UB-15MS10 Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Reflow the solder of the black and red wires from the circuit board by using the soldering iron.
    • For more information about using a soldering iron click here.
결론
작성자
8다른 기여자 명과 함께
Jordan Turk
회원 가입일: 09/21/15
331 평판
안내서 2개를 작성함
IUPUI, Team 2-1, Baechle Fall 2015 IUPUI, Team 2-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G1
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 856
