주요 콘텐츠로 건너뛰기
Uniden D1483-3BK Circuit Board/Screen Replacement
필요한 것
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: 2 단계, 이미지 1/2 Uniden D1483-3BK Circuit Board/Screen Replacement: 2 단계, 이미지 2/2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: 3 단계, 이미지 1/1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 4 단계, 이미지 1/2 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: 4 단계, 이미지 2/2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: 5 단계, 이미지 1/3 Uniden D1483-3BK Circuit Board/Screen Replacement: 5 단계, 이미지 2/3 Uniden D1483-3BK Circuit Board/Screen Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: 6 단계, 이미지 1/2 Uniden D1483-3BK Circuit Board/Screen Replacement: 6 단계, 이미지 2/2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: 7 단계, 이미지 1/2 Uniden D1483-3BK Circuit Board/Screen Replacement: 7 단계, 이미지 2/2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: 8 단계, 이미지 1/1
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: 9 단계, 이미지 1/1
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Arbitrary Name
회원 가입일: 01/28/15
1,083 평판
안내서 4개 작성하였습니다
Penn State, Team 1-8, Kaschak Winter 2015 Penn State, Team 1-8, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S1G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 293
