주요 콘텐츠로 건너뛰기
Uniden D1685 front panel and keypad replacement
필요한 것
  1. Uniden D1685 front panel and keypad replacement, Front Panel and Keypad: 1 단계, 이미지 1/1
    • Turn the phone over with the back facing upwards.
  2. Uniden D1685 front panel and keypad replacement: 2 단계, 이미지 1/1
    • Press your thumb down on the top of the cover and push downwards.
  3. Uniden D1685 front panel and keypad replacement: 3 단계, 이미지 1/1
    • Once removed the battery will be connected by 2 wires.
    • Do not pull the red and black wires.
  4. Uniden D1685 front panel and keypad replacement: 4 단계, 이미지 1/1
    • Pull the small, grey connector that is connected to the phone to disconnect the battery pack.
  5. Uniden D1685 front panel and keypad replacement: 5 단계, 이미지 1/2 Uniden D1685 front panel and keypad replacement: 5 단계, 이미지 2/2
    • Remove the two 3.175 mm screws with the small Phillips head (PH1) screwdriver on the bottom of the phone next to where the battery was removed.
  6. Uniden D1685 front panel and keypad replacement: 6 단계, 이미지 1/2 Uniden D1685 front panel and keypad replacement: 6 단계, 이미지 2/2
    • Once removed, use plastic opening tool to pull the back and front apart in 3 different locations; the bottom and both sides.
  7. Uniden D1685 front panel and keypad replacement: 7 단계, 이미지 1/1
    • After splitting the phone there will be 2 wires that connect the phone's circuit board with the speaker on the back.
  8. Uniden D1685 front panel and keypad replacement: 8 단계, 이미지 1/1
    • The circuit board (Large Green) is attached by 1 3.175mm screw in the top, left corner.
    • Remove this screw using a small Phillips head screwdriver (PH!) from the iFixit toolkit.
  9. Uniden D1685 front panel and keypad replacement: 9 단계, 이미지 1/1
    • Once the screw has been removed, the circuit board will be removable.
    • Gently remove the circuit board and place it on the back of the phone.
  10. Uniden D1685 front panel and keypad replacement: 10 단계, 이미지 1/2 Uniden D1685 front panel and keypad replacement: 10 단계, 이미지 2/2
    • The keyboard will now be accessible. Remove the Bumper Pad (rubber pad behind actual keypad).
    • Remove the keypad.
  11. Uniden D1685 front panel and keypad replacement: 11 단계, 이미지 1/2 Uniden D1685 front panel and keypad replacement: 11 단계, 이미지 2/2
    • Clean the pad with cleaning spray and/or a brush.
  12. Uniden D1685 front panel and keypad replacement: 12 단계, 이미지 1/1
    • Once cleaned, make sure to dry off all of the components entirely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Mullens
회원 가입일: 03/27/15
215 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-4, Naidoo Spring 2015 University of Alabama, Team 1-4, Naidoo Spring 2015 회원
UA-NAIDOO-S15S1G4
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
Did all of the above but I can’t get the center piece to work! I have no volume control and I can’t access anything like phone numbers, etc.
Honda Dude - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 306
