주요 콘텐츠로 건너뛰기
Uniden D1688 Bottom Circuit Board Replacement
필요한 것
  1. Uniden D1688 Bottom Circuit Board Replacement, Uniden D1688 Base Replacement: 1 단계, 이미지 1/1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Bottom Circuit Board Replacement: 2 단계, 이미지 1/2 Uniden D1688 Bottom Circuit Board Replacement: 2 단계, 이미지 2/2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
  3. Uniden D1688 Bottom Circuit Board Replacement, Top Circuit Board: 3 단계, 이미지 1/1
    • Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 Bottom Circuit Board Replacement: 4 단계, 이미지 1/1
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 Bottom Circuit Board Replacement: 5 단계, 이미지 1/1
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 Bottom Circuit Board Replacement: 6 단계, 이미지 1/1
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 Bottom Circuit Board Replacement: 7 단계, 이미지 1/1
    • Remove top shell circuit board by lifting the circuit board out of the case
  8. Uniden D1688 Bottom Circuit Board Replacement, Bottom Circuit Board: 8 단계, 이미지 1/1
    • Unscrew bottom shell circuit board screws(Head size: 4mm Length: 8.6mm).
  9. Uniden D1688 Bottom Circuit Board Replacement: 9 단계, 이미지 1/1
    • Lift bottom circuit board from the bottom shell.
결론
justin
회원 가입일: 01/26/15
419 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 1-4, Prince Winter 2015 Pasco Hernando, Team 1-4, Prince Winter 2015 회원
PHSC-PRINCE-W15S1G4
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 13
전체 시간: 327
