주요 콘텐츠로 건너뛰기
Uniden D1688 Handheld Replacement
필요한 것
  1. Uniden D1688 Handheld Replacement, Uniden D1688 Handheld Replacement: 1 단계, 이미지 1/2 Uniden D1688 Handheld Replacement, Uniden D1688 Handheld Replacement: 1 단계, 이미지 2/2
    • Slide the battery cover off of the handset, and unplug the battery.
  2. Uniden D1688 Handheld Replacement: 2 단계, 이미지 1/1
    • Remove the battery, and unscrew the two screws(Head Size: 4mm Length: 8.6 mm).
  3. Uniden D1688 Handheld Replacement: 3 단계, 이미지 1/1
    • Use spudger to separate the phone shell.
  4. Uniden D1688 Handheld Replacement: 4 단계, 이미지 1/1
    • Unscrew the two screws(Head Size: 4mm Length: 8.6mm) on the bottom shell keeping the speaker locking pin in place.
  5. Uniden D1688 Handheld Replacement: 5 단계, 이미지 1/1
    • Remove screw (4mm head,8.6mm length) from circuit board.
  6. Uniden D1688 Handheld Replacement: 6 단계, 이미지 1/1
    • Remove the rubber keyboard layer.
  7. Uniden D1688 Handheld Replacement: 7 단계, 이미지 1/1
    • Remove plastic buttons from outer shell.
결론
justin
회원 가입일: 01/26/15
419 평판
안내서 4개 작성하였습니다
Pasco Hernando, Team 1-4, Prince Winter 2015 Pasco Hernando, Team 1-4, Prince Winter 2015 회원
PHSC-PRINCE-W15S1G4
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 253
