주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Uniden Dect 6.0 Keyboard Replacement
필요한 것
  1. Uniden Dect 6.0 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Uniden Dect 6.0 Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Megan Lawrence
회원 가입일: 01/14/15
534 평판
안내서 5개를 작성함
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G3
4 회원들
안내서 18개를 작성함
1가이드 댓글
Great to have this guide! I’d add that (at least on my aging handset). Prying it open can feel a bit sketchy cause it may resist a bit, so I used the metal spudger to go around the edge lifting the tabs. But the plastic on these is pretty great and will not break even puting some force on it.
Also be mindful of the speaker on the back which is connected to the front case.
Ivan Viales - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 33
전체 시간: 3,755
