주요 콘텐츠로 건너뛰기
Uniden EXP 371 Charging Contact Points Replacement
필요한 것
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: 1 단계, 이미지 1/2 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: 1 단계, 이미지 2/2
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: 2 단계, 이미지 1/1
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: 3 단계, 이미지 1/1
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: 4 단계, 이미지 1/2 Uniden EXP 371 Charging Contact Points Replacement: 4 단계, 이미지 2/2
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
결론
Eric Rodrigues
회원 가입일: 10/16/14
343 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 143
