주요 콘텐츠로 건너뛰기
Uniden EXP 371 Keypad Replacement
필요한 것
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: 1 단계, 이미지 1/1
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: 2 단계, 이미지 1/3 Uniden EXP 371 Keypad Replacement: 2 단계, 이미지 2/3 Uniden EXP 371 Keypad Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: 3 단계, 이미지 1/2 Uniden EXP 371 Keypad Replacement: 3 단계, 이미지 2/2
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: 4 단계, 이미지 1/1
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: 5 단계, 이미지 1/2 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: 5 단계, 이미지 2/2
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: 6 단계, 이미지 1/1
결론
Lucas Mohsen
회원 가입일: 10/31/14
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-1, Duarte Fall 2014 UMass Dartmouth, Team 2-1, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 11
전체 시간: 144
