주요 콘텐츠로 건너뛰기
Uniden Guardian G955 Battery Replacement
필요한 것
  1. Uniden Guardian G955 Battery  Replacement, Battery: 1 단계, 이미지 1/1
    • First, remove four 6.1 mm screws from your monitor using a J1 Phillips head screwdriver.
  2. Uniden Guardian G955 Battery  Replacement: 2 단계, 이미지 1/1
    • Carefully, use a metal spudger to open the case starting from any corner.
    • Slowly slide the spudger along the inside edge of the case.
  3. Uniden Guardian G955 Battery  Replacement: 3 단계, 이미지 1/2 Uniden Guardian G955 Battery  Replacement: 3 단계, 이미지 2/2
    • Remove the two 6.1 mm screws from the black fastener using a screwdriver.
    • Remove the black fastener.
  4. Uniden Guardian G955 Battery  Replacement: 4 단계, 이미지 1/2 Uniden Guardian G955 Battery  Replacement: 4 단계, 이미지 2/2
    • Disconnect the head of the cable attached to the motherboard by pressing on the outer edge of the cable and sliding it out.
  5. Uniden Guardian G955 Battery  Replacement: 5 단계, 이미지 1/2 Uniden Guardian G955 Battery  Replacement: 5 단계, 이미지 2/2
    • Remove the battery from the case by sliding a halberd spudger below it. (note: the spudger shown is metal, to ensure proper safety, utilize a nylon or plastic spudger.)
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sundus Al Shibani
회원 가입일: 10/04/16
180 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Nance Fall 2016 USF Tampa, Team 1-1, Nance Fall 2016 회원
USFT-NANCE-F16S1G1
3 회원들
안내서 8개 작성하였습니다
댓글 4개
The instructions and illustrations are fine, but there is NO information on how to obtain a replacement battery. I have searched without any luck.
Ricaedo Garcia - 답글
Hello, I sure hope I can get a answer on this, Ricaedo Garcia was you able to find a replacement battery for yours. I been searching for one and no luck. Thank you
Kathy -
I’m going to try using this battery: YK843553-Battery-for-UNIDEN-UBW2101C-Camera-UBWC21-1250mAh
I think it will work. The connector and voltage are the same.
George Scott - 답글
George Scott: Did that battery work satisfactorily?
PhBob - - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 5,765
