이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The circuit board is the main operating point of the TCX905. This has many wires soldered to it and must be handled carefully. The circuit board has the microphone and the LCD screen connected to it.
필요한 것
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
