주요 콘텐츠로 건너뛰기
Uniden TCX905 Earpiece Speaker Replacement
필요한 것
  1. Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: 1 단계, 이미지 1/2 Uniden TCX905 Earpiece Speaker Replacement, Battery Cover: 1 단계, 이미지 2/2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: 2 단계, 이미지 1/2 Uniden TCX905 Earpiece Speaker Replacement, Battery Pack: 2 단계, 이미지 2/2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Earpiece Speaker Replacement, Back Shell: 3 단계, 이미지 1/2 Uniden TCX905 Earpiece Speaker Replacement, Back Shell: 3 단계, 이미지 2/2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Earpiece Speaker Replacement: 4 단계, 이미지 1/3 Uniden TCX905 Earpiece Speaker Replacement: 4 단계, 이미지 2/3 Uniden TCX905 Earpiece Speaker Replacement: 4 단계, 이미지 3/3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Earpiece Speaker Replacement: 5 단계, 이미지 1/3 Uniden TCX905 Earpiece Speaker Replacement: 5 단계, 이미지 2/3 Uniden TCX905 Earpiece Speaker Replacement: 5 단계, 이미지 3/3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: 6 단계, 이미지 1/2 Uniden TCX905 Earpiece Speaker Replacement, Circuit Board: 6 단계, 이미지 2/2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Earpiece Speaker Replacement: 7 단계, 이미지 1/3 Uniden TCX905 Earpiece Speaker Replacement: 7 단계, 이미지 2/3 Uniden TCX905 Earpiece Speaker Replacement: 7 단계, 이미지 3/3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 1/2 Uniden TCX905 Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 2/2
    • Place circuit board gently on the back shell with the earpiece facing up
  9. Uniden TCX905 Earpiece Speaker Replacement: 9 단계, 이미지 1/3 Uniden TCX905 Earpiece Speaker Replacement: 9 단계, 이미지 2/3 Uniden TCX905 Earpiece Speaker Replacement: 9 단계, 이미지 3/3
    • Pry speaker gently from setting using tweezers
    • Cut red and black wires near the soldering
결론
Gary Pence
회원 가입일: 03/26/14
807 평판
안내서 8개 작성하였습니다
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014 회원
CLEM-BENSON-S14S1G1
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 483
