주요 콘텐츠로 건너뛰기
Uniden UTAB71 Camera Replacement
필요한 것
  1. Uniden UTAB71 Camera Replacement, Camera: 1 단계, 이미지 1/2 Uniden UTAB71 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: 2 단계, 이미지 1/2 Uniden UTAB71 Camera Replacement: 2 단계, 이미지 2/2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: 3 단계, 이미지 1/1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: 4 단계, 이미지 1/3 Uniden UTAB71 Camera Replacement: 4 단계, 이미지 2/3 Uniden UTAB71 Camera Replacement: 4 단계, 이미지 3/3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
결론
Ryan Jewell
회원 가입일: 10/20/16
422 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 182
