주요 콘텐츠로 건너뛰기
Uniden UTAB71 Screen Replacement
필요한 것
  1. Uniden UTAB71 Screen Replacement, Screen: 1 단계, 이미지 1/2 Uniden UTAB71 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Use a pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Screen Replacement: 2 단계, 이미지 1/2 Uniden UTAB71 Screen Replacement: 2 단계, 이미지 2/2
    • Lift off the black clip connecting the first power ribbon to the motherboard
    • Undo the clips off the second power ribbon connecting the screen to the motherboard.
  3. Uniden UTAB71 Screen Replacement: 3 단계, 이미지 1/3 Uniden UTAB71 Screen Replacement: 3 단계, 이미지 2/3 Uniden UTAB71 Screen Replacement: 3 단계, 이미지 3/3
    • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
    • Do not apply too much pressure on the tablet casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Jewell
회원 가입일: 10/20/16
422 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-4, Martin Fall 2016 UMass Dartmouth, Team 5-4, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 359
