이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
Disconnect the wiring from the electrical components in the panel.
Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
Open the drain valve on the water heater by turning it counter-clockwise.
Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
