주요 콘텐츠로 건너뛰기
Unnecto Drone M Headphone Jack Replacement
필요한 것
  1. Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: 1 단계, 이미지 1/2 Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: 1 단계, 이미지 2/2
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Headphone Jack Replacement: 5 단계, 이미지 1/2 Unnecto Drone M Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Headphone Jack Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Headphone Jack Replacement: 7 단계, 이미지 1/1
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Headphone Jack Replacement: 8 단계, 이미지 1/2 Unnecto Drone M Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 9 단계, 이미지 1/3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 9 단계, 이미지 2/3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: 9 단계, 이미지 3/3
    • Desolder the headphone jack using a soldering iron on each of the 6 points holding it down.
    • Be careful to not damage the circuit board.
  10. Unnecto Drone M Headphone Jack Replacement: 10 단계, 이미지 1/2 Unnecto Drone M Headphone Jack Replacement: 10 단계, 이미지 2/2
    • Solder on a new headphone jack.
  11. Unnecto Drone M Headphone Jack Replacement: 11 단계, 이미지 1/1
    • Make sure the new jack is aligned properly and securely soldered to the circuit board.
결론
John Stavrianopoulos
회원 가입일: 02/08/18
175 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 196
