주요 콘텐츠로 건너뛰기
Unsticking SteelSeries Nimbus Triggers
필요한 것
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: 1 단계, 이미지 1개 중 1개
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: 2 단계, 이미지 2개 중 1개 Unsticking SteelSeries Nimbus Triggers: 2 단계, 이미지 2개 중 2개
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: 3 단계, 이미지 3개 중 1개 Unsticking SteelSeries Nimbus Triggers: 3 단계, 이미지 3개 중 2개 Unsticking SteelSeries Nimbus Triggers: 3 단계, 이미지 3개 중 3개
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: 4 단계, 이미지 2개 중 1개 Unsticking SteelSeries Nimbus Triggers: 4 단계, 이미지 2개 중 2개
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: 5 단계, 이미지 3개 중 1개 Unsticking SteelSeries Nimbus Triggers: 5 단계, 이미지 3개 중 2개 Unsticking SteelSeries Nimbus Triggers: 5 단계, 이미지 3개 중 3개
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: 6 단계, 이미지 3개 중 1개 Unsticking SteelSeries Nimbus Triggers: 6 단계, 이미지 3개 중 2개 Unsticking SteelSeries Nimbus Triggers: 6 단계, 이미지 3개 중 3개
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: 7 단계, 이미지 2개 중 1개 Unsticking SteelSeries Nimbus Triggers: 7 단계, 이미지 2개 중 2개
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan
회원 가입일: 03/13/13
464 평판
안내서 2개를 작성함
4가이드 댓글
Great, concise fix instructions!
Brian Pippen - 답글
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - 답글
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - 답글
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 55
전체 시간: 6,621
