주요 콘텐츠로 건너뛰기
Untracked Bifold Door Pin Replacement
필요한 것
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: 1 단계, 이미지 1/1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: 2 단계, 이미지 1/1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: 3 단계, 이미지 1/1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: 4 단계, 이미지 1/2 Untracked Bifold Door Pin Replacement: 4 단계, 이미지 2/2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: 5 단계, 이미지 1/1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: 6 단계, 이미지 1/1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: 7 단계, 이미지 1/1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: 8 단계, 이미지 1/1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: 9 단계, 이미지 1/1
    • When completed, the bifold doors should close and be positioned within the tracking.
결론
Catelyn Carpenter
회원 가입일: 01/16/20
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 49
전체 시간: 1,397
