주요 콘텐츠로 건너뛰기
Upgrading iMac Intel 21.5" EMC 2544 RAM Memory
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Unglue the screen: 1 단계, 이미지 1개 중 1개
    • First you need to remove the glue from the edge of the iMac
    • Use a Guitar Pick around the screen to remove the glue
    • Be careful not to damage the iSight camera
  2. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Screen: 2 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Screen: 2 단계, 이미지 2개 중 2개
    • Once you are sure the adhesive is removed, use two heavy suction cups to lift the screen
    • Unplug these cables:
    • DisplayPort Cable
    • Power Cable
    • Lift the screen from the iMac
  3. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Adhesive: 3 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Adhesive: 3 단계, 이미지 2개 중 2개
    • Remove the gray tape from the iMac and the screen itself
    • When reassembling the iMac, put double sided tape on the screen and the iMac
  4. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Hard drive: 4 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Hard drive: 4 단계, 이미지 2개 중 2개
    • Remove the four Torx T10 screws
    • Unplug the SATA cables and remove the hard drive
  5. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Fan: 5 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Fan: 5 단계, 이미지 2개 중 2개
    • Remove these 3 Torx T10 screws
    • After you remove the screws, remove these cables
    • Fan Cable
    • Unstick and unplug the camera cable
    • After you remove the fan, remove the hard drive bay removing a single Torx T10 screw
  6. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Power board: 6 단계, 이미지 3개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Power board: 6 단계, 이미지 3개 중 2개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Power board: 6 단계, 이미지 3개 중 3개
    • Remove these 2 Torx T10 screws
    • Unplug these 2 cables
    • Unplug 2 more cable below the power board by pressing the clip
    • The power board is hard to remove from its place, remove it carefully
  7. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory: 7 단계, 이미지 1개 중 1개
    • Remove the cables out of the clip
  8. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory: 8 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory: 8 단계, 이미지 2개 중 2개
    • Unplug these 4 antenna connectors
    • When reassembling be sure that the connectors are in the same place
    • After that, remove these two Torx T10 screws
    • Move the speaker and unplug the cable from the logic board
    • Remove these other cables
    • For finish, remove these four Torx T10 screws
  9. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Logic Board: 9 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, Logic Board: 9 단계, 이미지 2개 중 2개
    • Unscrew 3 Torx T8 screws from the heatsink, then remove the logic board from the iMac
    • Be careful not to damage the SD card reader with the screw mount
  10. Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, RAM memory: 10 단계, 이미지 2개 중 1개 Upgrading iMac Intel 21.5" EMC 2544 RAM Memory, RAM memory: 10 단계, 이미지 2개 중 2개
    • Flip the logic board over and release the tabs from each side of the RAM
결론
To reassemble your device, follow these instructions in reverse order remembering to re-glue the screen.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
jimenezser
회원 가입일: 08/29/12
3,899 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 29,674
