주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Engage Wired Optical Mouse Upper Board Removal
필요한 것
  1. Engage Wired Optical Mouse Upper Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 1 단계, 이미지 1개 중 1개
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Upper Board Removal: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Upper Board Removal: 3 단계, 이미지 3개 중 1개 Engage Wired Optical Mouse Upper Board Removal: 3 단계, 이미지 3개 중 2개 Engage Wired Optical Mouse Upper Board Removal: 3 단계, 이미지 3개 중 3개
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Upper Board Removal: 4 단계, 이미지 1개 중 1개
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Upper Board Removal: 5 단계, 이미지 2개 중 1개 Engage Wired Optical Mouse Upper Board Removal: 5 단계, 이미지 2개 중 2개
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Engage Wired Optical Mouse Upper Board Removal, Top Shell: 6 단계, 이미지 1개 중 1개
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  7. Engage Wired Optical Mouse Upper Board Removal, Upper Board: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
  8. Engage Wired Optical Mouse Upper Board Removal: 8 단계, 이미지 2개 중 1개 Engage Wired Optical Mouse Upper Board Removal: 8 단계, 이미지 2개 중 2개
    • Pinch the cage to release snaps. You can now pull the cage off.
  9. Engage Wired Optical Mouse Upper Board Removal: 9 단계, 이미지 1개 중 1개
    • Remove the screw holding the circuit board down.
    • The board will now pop off easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David
회원 가입일: 01/16/13
1,301 평판
안내서 4개를 작성함
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 회원
CPSU-REGAN-W13S18G36
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 1,094
