주요 콘텐츠로 건너뛰기
Urbanears Stammen Speaker not working: repair guide
필요한 것
  1. Urbanears Stammen Speaker not working: repair guide, Speaker Dissassembly: 1 단계, 이미지 2개 중 1개 Urbanears Stammen Speaker not working: repair guide, Speaker Dissassembly: 1 단계, 이미지 2개 중 2개
    • With a metal spudger or a dull bread knife with a large surface, pry open the side cover of the speaker that is attached to the body by sticky tape. Take you time, the adhesive is very strong. Be careful not to damage the wooden body of the speaker during prying.
  2. Urbanears Stammen Speaker not working: repair guide: 2 단계, 이미지 3개 중 1개 Urbanears Stammen Speaker not working: repair guide: 2 단계, 이미지 3개 중 2개 Urbanears Stammen Speaker not working: repair guide: 2 단계, 이미지 3개 중 3개
    • Next, continue by removing the screws hidden under these 6 rubber feet. Use a spudger to remove the rubber feet. Use a large philips screw driver for the screws. Then, remove the bottom cover, but be mindful to first remove the internal power cable that is attached to the internal power supply of the speaker (marked in red, last image).
  3. Urbanears Stammen Speaker not working: repair guide: 3 단계, 이미지 2개 중 1개 Urbanears Stammen Speaker not working: repair guide: 3 단계, 이미지 2개 중 2개
    • Remove the 6 screws on the side of the speaker the loosen the lower side panel. The main board of the speaker is attached to the inside of this lower side panel (Marked in red, second image). The board is attached to other components with cables. Be mindful to unplug each cable carefully upon removing the side panel.
  4. Urbanears Stammen Speaker not working: repair guide: 4 단계, 이미지 2개 중 1개 Urbanears Stammen Speaker not working: repair guide: 4 단계, 이미지 2개 중 2개
    • The main board consists of 2 board seperarte boards stacked together. The lower larger board hosts the TPS54335A. The function is to reduce the incoming 18V to a lower voltage suitable for the main processing chips. Uncrew the top board carfully to make space. Beware to shield any plastic connectors from hot air upon replacing the TPS54335A.
결론
After replacing the TPS54335A, re-assemble the speaker by following the steps in reversed order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
michaelboot
회원 가입일: 08/13/12
151 평판
안내서 1개를 작성함
2가이드 댓글
Thanks for the guide! I had managed to open the device and analyze the problem, but this page reassured me that it was indeed due to a defective TPS54335A chip. I went to to have it replaced by a professional repair shop and the speaker immediately started working again.
Peter Schneider - 답글
Thanks a lot for the guide! The TPS54335A was also defective in my speaker, and I replaced it. It helps a lot to remove the heat sink on the back while soldering.
Unfortunately, I still have a short circuit in the plugged-in WiFi and Bluetooth board with the large heat sink. It appears to be a ready-made module FS5332 from Frontier Silicon. But the components are much too small and some are BGAs, so I can't figure out what is broken. Does anyone have any idea what could be wrong on the module or a tip where I can buy the whole module?
idontpaul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 74
전체 시간: 525
