주요 콘텐츠로 건너뛰기
Urge Basics Soundbrick Speaker Woofer Replacement
필요한 것
  1. Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: 1 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: 1 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: 1 단계, 이미지 3/3
    • Flip the speaker upside down.
    • Unscrew the middle screw with a Philips #1 screwdriver.
  2. Urge Basics Soundbrick Speaker Woofer Replacement: 2 단계, 이미지 1/2 Urge Basics Soundbrick Speaker Woofer Replacement: 2 단계, 이미지 2/2
    • Peel off the two gray tabs to expose the four inner Philips #1 screws.
  3. Urge Basics Soundbrick Speaker Woofer Replacement: 3 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 3 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 3 단계, 이미지 3/3
    • Unscrew all four screws with a Philips #1 screwdriver.
    • The screws are deep and can be difficult to take out.
  4. Urge Basics Soundbrick Speaker Woofer Replacement: 4 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 4 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 4 단계, 이미지 3/3
    • Flip the speaker so that the ports are facing up.
    • Unfold the speaker's cover away from the body.
  5. Urge Basics Soundbrick Speaker Woofer Replacement: 5 단계, 이미지 1/2 Urge Basics Soundbrick Speaker Woofer Replacement: 5 단계, 이미지 2/2
    • Remove the two Phillips #1 screws found on each side of the battery compartment.
    • Removal of battery compartment is necessary to prevent electric shock when replacing the woofer.
  6. Urge Basics Soundbrick Speaker Woofer Replacement: 6 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 6 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery connectors attached to the circuit board by unplugging them.
  7. Urge Basics Soundbrick Speaker Woofer Replacement: 7 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 7 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 7 단계, 이미지 3/3
    • Disconnect the ribbon cable from the battery by carefully pulling it out.
    • Remove the battery compartment.
  8. Urge Basics Soundbrick Speaker Woofer Replacement: 8 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 8 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 8 단계, 이미지 3/3
    • Disconnect the adjacent connector from the main circuit board.
  9. Urge Basics Soundbrick Speaker Woofer Replacement: 9 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 9 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 9 단계, 이미지 3/3
    • Disconnect the woofer's two connectors from the main circuit board.
  10. Urge Basics Soundbrick Speaker Woofer Replacement: 10 단계, 이미지 1/3 Urge Basics Soundbrick Speaker Woofer Replacement: 10 단계, 이미지 2/3 Urge Basics Soundbrick Speaker Woofer Replacement: 10 단계, 이미지 3/3
    • Remove the two Phillips #1 screws keeping each woofer in place.
    • Carefully remove the woofers and replace them with new ones.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Itzel Urueta
회원 가입일: 04/28/17
125 평판
안내서 1개 작성함
UC Davis, Team S2-G4, Cole Spring 2017 UC Davis, Team S2-G4, Cole Spring 2017 회원
UCD-COLE-S17S2G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 867
