주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Using a Floor Jack
필요한 것
  1. Using a Floor Jack, Using a Floor Jack: 1 단계, 이미지 2개 중 1개 Using a Floor Jack, Using a Floor Jack: 1 단계, 이미지 2개 중 2개
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. Using a Floor Jack, Using floor jack to lift car.: 2 단계, 이미지 1개 중 1개
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. Using a Floor Jack: 3 단계, 이미지 1개 중 1개
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. Using a Floor Jack: 4 단계, 이미지 1개 중 1개
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Shaun MacDonald
회원 가입일: 10/03/12
2,654 평판
안내서 8개를 작성함
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 회원
CPSU-REGAN-F12S24G27
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 47
지난 30일: 207
전체 시간: 43,455
