소개
This guide covers the replacement of a VANKEY keyboard wrist rest's outer cover. This wrist rest is pad of a non-stick pad with a cellulose foam on top for comfort. An outer covered is adhered to the pad and foam by a weak adhesive which can fail after prolonged use. The cover can also be stained or torn beyond repair, necessitating its replacement. The cover is replaced by first peeling off the current cover, then cutting out and gluing on a new cover.
Potential replacement materials are light leather and spandex, or another tight, breathable, fabric. Synthetic fabrics, such as those used in athletic shirts, are encouraged.
The tools request the use of Aleene's FLEXABLE Stretchable Glue, which is designed for adhering synthetic fabrics, but Elmer's glue sticks are a suitable short term replacement. Elmer's glue is not advised for a long term fix as it's longevity is questionable.
필요한 것
Peel back the outer cover from the non-stick pad underneath using a knife to get between the cover and the dense foam of the pad.
If you find that your new cover begins to peel off, try using a different adhesive more specialized to the fabric of the new cover.
다른 한 분이 해당 안내서를 완성하였습니다.
