주요 콘텐츠로 건너뛰기
VENSTAR Taco Disassembly
필요한 것
  1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: 1 단계, 이미지 1/3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: 1 단계, 이미지 2/3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: 1 단계, 이미지 3/3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Disassembly: 2 단계, 이미지 1/2 VENSTAR Taco Disassembly: 2 단계, 이미지 2/2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Disassembly: 3 단계, 이미지 1/2 VENSTAR Taco Disassembly: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Disassembly: 4 단계, 이미지 1/2 VENSTAR Taco Disassembly: 4 단계, 이미지 2/2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Disassembly: 5 단계, 이미지 1/2 VENSTAR Taco Disassembly: 5 단계, 이미지 2/2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
결론
Michael Thompson
회원 가입일: 01/31/16
194 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 405
