주요 콘텐츠로 건너뛰기
VHS Shell Replacement
필요한 것
  1. VHS Shell Replacement, Plastic Shell: 1 단계, 이미지 2개 중 1개 VHS Shell Replacement, Plastic Shell: 1 단계, 이미지 2개 중 2개
    • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
  2. VHS Shell Replacement: 2 단계, 이미지 1개 중 1개
    • Once the screws are out, pull off the front of the VHS shell.
    • Take off any labels on the sides of tape before doing this step.
    • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
  3. VHS Shell Replacement: 3 단계, 이미지 2개 중 1개 VHS Shell Replacement: 3 단계, 이미지 2개 중 2개
    • Hold down on the white lever.
    • While holding down, carefully take out the reel on the right.
    • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
  4. VHS Shell Replacement: 4 단계, 이미지 2개 중 1개 VHS Shell Replacement: 4 단계, 이미지 2개 중 2개
    • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
    • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
  5. VHS Shell Replacement: 5 단계, 이미지 1개 중 1개
    • Once the screws are out, pull off the front of the replacement shell.
  6. VHS Shell Replacement: 6 단계, 이미지 1개 중 1개
    • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
    • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
  7. VHS Shell Replacement: 7 단계, 이미지 1개 중 1개
    • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
  8. VHS Shell Replacement: 8 단계, 이미지 1개 중 1개
    • Turn the reels to retract any excess tape hanging out of the top.
    • This isn't a necessary step, just one that I prefer to do.
  9. VHS Shell Replacement: 9 단계, 이미지 1개 중 1개
    • Place the top of the replacement shell back on.
  10. VHS Shell Replacement: 10 단계, 이미지 1개 중 1개
    • Screw the screws back in with a screwdriver.
결론
작성자
2다른 기여자 명과 함께
McKinley Hixon
회원 가입일: 03/19/21
202 평판
안내서 1개를 작성함
2가이드 댓글
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - 답글
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 96
전체 시간: 2,981
