주요 콘텐츠로 건너뛰기
VTech Baby's Learning Laptop Battery and Rear Panel Replacement
필요한 것
  1. VTech Baby's Learning Laptop Battery and Rear Panel Replacement, Battery and Rear Panel: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 2 단계, 이미지 1/1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 3 단계, 이미지 1/1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 4 단계, 이미지 1/2 VTech Baby's Learning Laptop Battery and Rear Panel Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Kourmoulakis
회원 가입일: 09/03/15
373 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 19
전체 시간: 1,114
