주요 콘텐츠로 건너뛰기
VTech Baby's Learning Laptop Mode Switch Replacement
필요한 것
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mode Switch Replacement: 2 단계, 이미지 1/1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mode Switch Replacement: 3 단계, 이미지 1/1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mode Switch Replacement: 4 단계, 이미지 1/2 VTech Baby's Learning Laptop Mode Switch Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 5 단계, 이미지 1/2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 5 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 1/3 VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 2/3 VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 3/3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mode Switch Replacement: 7 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
  8. VTech Baby's Learning Laptop Mode Switch Replacement: 8 단계, 이미지 1/1
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
결론
Scott Parkinson
회원 가입일: 09/09/15
107 평판
안내서 1개 작성함
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 501
