주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The base's motherboard is attached via wires, to the bracket of the charging contact points.
부품
지정된 부품이 없습니다.
  1. Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back. Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back.
    • Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back.
  2. Facing the bottom side of the base, run the black spudger along the crevice to one side, and then to the other. With a gentle application of force, the two parts of the base's body should separate.
    • Facing the bottom side of the base, run the black spudger along the crevice to one side, and then to the other.
    • With a gentle application of force, the two parts of the base's body should separate.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Hold the anterior part of the base's body, with the side which shows only the exterior, facing the palm.
    • Hold the anterior part of the base's body, with the side which shows only the exterior, facing the palm.
    • Unscrew the 10.0mm Philips #0 round head screw, located on the black bracket which holds the charger contact points.
    • The black bracket should pop off.
  5. Gently pull up on motherboard, in order to separate it from the base.
    • Gently pull up on motherboard, in order to separate it from the base.
결론
Sheckeem Daley
회원 가입일: 2016년 02월 04일
540 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Blackwell Winter 2016 USF Tampa, Team 16-4, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G4
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 541
