주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The compatible battery available on the official VTech website for the CS6114 cordless phone costs the same as a new CS6114 phone.
도구
지정된 도구가 없습니다.
부품
  1. Hold handset with one hand with the keypad facing downward.
    • Hold handset with one hand with the keypad facing downward.
  2. Place thumb on the indentation located at the top of the battery cover. Press down and gently slide the cover off  the back of the handset. Set the battery cover aside.
    • Place thumb on the indentation located at the top of the battery cover.
    • Press down and gently slide the cover off the back of the handset.
    • Set the battery cover aside.
  3. Use thumb and index finger to gently pull the wired connection from the handset. Remove the battery. Remove the battery.
    • Use thumb and index finger to gently pull the wired connection from the handset.
    • Remove the battery.
결론
Sheckeem Daley
회원 가입일: 2016년 02월 04일
519 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Blackwell Winter 2016 USF Tampa, Team 16-4, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G4
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 81
전체 시간: 1,668
