주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The handset motherboard has the display screen and speaker attached. We will be replacing the motherboard with these pieces still attached.
부품
지정된 부품이 없습니다.
  1. Hold handset with one hand with the keypad facing downward.
    • Hold handset with one hand with the keypad facing downward.
  2. Place thumb on the indentation located at the top of the battery cover. Press down and gently slide the cover off  the back of the handset. Set the battery cover aside.
    • Place thumb on the indentation located at the top of the battery cover.
    • Press down and gently slide the cover off the back of the handset.
    • Set the battery cover aside.
  3. Use thumb and index finger to gently pull the wired connection from the handset. Remove the battery. Remove the battery.
    • Use thumb and index finger to gently pull the wired connection from the handset.
    • Remove the battery.
  4. Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
    • Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
  5. Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone. Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone. Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
    • Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
  6. Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard. Remove the handset motherboard.
    • Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard.
    • Remove the handset motherboard.
결론
Sheckeem Daley
회원 가입일: 2016년 02월 04일
519 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Blackwell Winter 2016 USF Tampa, Team 16-4, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G4
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 382
