주요 콘텐츠로 건너뛰기
VTech CS6719-2 Screen Replacement
필요한 것
  1. VTech CS6719-2  Screen Replacement, Battery: 1 단계, 이미지 1/2 VTech CS6719-2  Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2  Screen Replacement: 2 단계, 이미지 1/1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2  Screen Replacement: 3 단계, 이미지 1/1
    • Unplug the battery input cable.
  4. VTech CS6719-2  Screen Replacement: 4 단계, 이미지 1/1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2  Screen Replacement, Circuit Board: 5 단계, 이미지 1/2 VTech CS6719-2  Screen Replacement, Circuit Board: 5 단계, 이미지 2/2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2  Screen Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2  Screen Replacement: 7 단계, 이미지 1/2 VTech CS6719-2  Screen Replacement: 7 단계, 이미지 2/2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2  Screen Replacement, Screen: 8 단계, 이미지 1/1
    • Remove the plastic screen.
결론
Joshua Woodward
회원 가입일: 02/08/16
122 평판
안내서 1개 작성함
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 281
