주요 콘텐츠로 건너뛰기
VTech InnoTab 2 Back Panel Replacement
필요한 것
  1. VTech InnoTab 2 Back Panel Replacement, Battery: 1 단계, 이미지 1/3 VTech InnoTab 2 Back Panel Replacement, Battery: 1 단계, 이미지 2/3 VTech InnoTab 2 Back Panel Replacement, Battery: 1 단계, 이미지 3/3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: 2 단계, 이미지 1/3 VTech InnoTab 2 Back Panel Replacement, Back Panel: 2 단계, 이미지 2/3 VTech InnoTab 2 Back Panel Replacement, Back Panel: 2 단계, 이미지 3/3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Back Panel Replacement: 3 단계, 이미지 1/3 VTech InnoTab 2 Back Panel Replacement: 3 단계, 이미지 2/3 VTech InnoTab 2 Back Panel Replacement: 3 단계, 이미지 3/3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Back Panel Replacement: 4 단계, 이미지 1/2 VTech InnoTab 2 Back Panel Replacement: 4 단계, 이미지 2/2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Back Panel Replacement: 5 단계, 이미지 1/2 VTech InnoTab 2 Back Panel Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
결론
Roberto Valdes
회원 가입일: 10/18/17
302 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G85
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 428
