주요 콘텐츠로 건너뛰기
VTech InnoTab 2 Backup Battery Replacement
필요한 것
  1. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: 1 단계, 이미지 1/3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: 1 단계, 이미지 2/3 VTech InnoTab 2 Backup Battery Replacement, Backup Battery: 1 단계, 이미지 3/3
    • The CR2032 compartment is located on bottom left corner on the backside of the device.
    • Unscrew the single 4 mm Phillip screw and slide the compartment cover off.
    • The 4 mm Phillip screw will not completely screw out of the cover.
  2. VTech InnoTab 2 Backup Battery Replacement: 2 단계, 이미지 1/3 VTech InnoTab 2 Backup Battery Replacement: 2 단계, 이미지 2/3 VTech InnoTab 2 Backup Battery Replacement: 2 단계, 이미지 3/3
    • Gently remove the CR2032 battery with your fingers.
    • A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
결론
Mark Lefcourt
회원 가입일: 10/18/17
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G85
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 455
