주요 콘텐츠로 건너뛰기
VTech InnoTab 2S Headphone Jack Replacement
필요한 것
  1. VTech InnoTab 2S Headphone Jack Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Headphone Jack Replacement: 2 단계, 이미지 1/2 VTech InnoTab 2S Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Headphone Jack Replacement: 3 단계, 이미지 1/3 VTech InnoTab 2S Headphone Jack Replacement: 3 단계, 이미지 2/3 VTech InnoTab 2S Headphone Jack Replacement: 3 단계, 이미지 3/3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Headphone Jack Replacement: 4 단계, 이미지 1/2 VTech InnoTab 2S Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Headphone Jack Replacement: 5 단계, 이미지 1/2 VTech InnoTab 2S Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Headphone Jack Replacement, Motherboard: 6 단계, 이미지 1/1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Headphone Jack Replacement: 7 단계, 이미지 1/1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Headphone Jack Replacement: 8 단계, 이미지 1/1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Headphone Jack Replacement: 9 단계, 이미지 1/1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Headphone Jack Replacement: 10 단계, 이미지 1/1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2S Headphone Jack Replacement, Headphone Jack: 11 단계, 이미지 1/1
    • First use the solderer tool to desolder the two points boxed in red on the image.
  12. VTech InnoTab 2S Headphone Jack Replacement: 12 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Flip over the circuit board.
    • Using the metal tweezers, firmly grasp the headphone jack on either side and pull up to remove.
결론
Esthevan Romeiro
회원 가입일: 10/06/16
261 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 회원
USFT-LACY-F16S5G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 185
