주요 콘텐츠로 건너뛰기
VTech InnoTab 2S Motherboard Removal
필요한 것
  1. VTech InnoTab 2S Motherboard Removal, Back Panel: 1 단계, 이미지 1개 중 1개
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Motherboard Removal: 2 단계, 이미지 2개 중 1개 VTech InnoTab 2S Motherboard Removal: 2 단계, 이미지 2개 중 2개
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Motherboard Removal: 3 단계, 이미지 3개 중 1개 VTech InnoTab 2S Motherboard Removal: 3 단계, 이미지 3개 중 2개 VTech InnoTab 2S Motherboard Removal: 3 단계, 이미지 3개 중 3개
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Motherboard Removal: 4 단계, 이미지 2개 중 1개 VTech InnoTab 2S Motherboard Removal: 4 단계, 이미지 2개 중 2개
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Motherboard Removal: 5 단계, 이미지 2개 중 1개 VTech InnoTab 2S Motherboard Removal: 5 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Motherboard Removal, Motherboard: 6 단계, 이미지 1개 중 1개
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Motherboard Removal: 7 단계, 이미지 1개 중 1개
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Motherboard Removal: 8 단계, 이미지 1개 중 1개
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Motherboard Removal: 9 단계, 이미지 1개 중 1개
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Motherboard Removal: 10 단계, 이미지 1개 중 1개
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
결승점
작성자
5다른 기여자 명과 함께
Ricardo Espinosa
회원 가입일: 10/06/16
221 평판
안내서 2개를 작성함
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 회원
USFT-LACY-F16S5G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 370
