주요 콘텐츠로 건너뛰기
VTech InnoTab 2s Back Panel Replacement
필요한 것
  1. VTech InnoTab 2s Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Back Panel Replacement: 2 단계, 이미지 1/2 VTech InnoTab 2s Back Panel Replacement: 2 단계, 이미지 2/2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Back Panel Replacement: 3 단계, 이미지 1/3 VTech InnoTab 2s Back Panel Replacement: 3 단계, 이미지 2/3 VTech InnoTab 2s Back Panel Replacement: 3 단계, 이미지 3/3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Back Panel Replacement: 4 단계, 이미지 1/2 VTech InnoTab 2s Back Panel Replacement: 4 단계, 이미지 2/2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Back Panel Replacement: 5 단계, 이미지 1/2 VTech InnoTab 2s Back Panel Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ricardo Espinosa
회원 가입일: 10/06/16
221 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 회원
USFT-LACY-F16S5G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 253
