주요 콘텐츠로 건너뛰기
VTech Kidizoom Action Cam Battery Replacement
필요한 것
  1. VTech Kidizoom Action Cam Battery Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Make sure that the master power switch is set to the (O) position.
  2. VTech Kidizoom Action Cam Battery Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
    • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
  3. VTech Kidizoom Action Cam Battery Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
    • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
    • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
  4. VTech Kidizoom Action Cam Battery Replacement: 4 단계, 이미지 1/1
    • Pry off the transparent plating and paper design using a plastic opening tool.
  5. VTech Kidizoom Action Cam Battery Replacement: 5 단계, 이미지 1/1
    • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
  6. VTech Kidizoom Action Cam Battery Replacement: 6 단계, 이미지 1/1
    • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
  7. VTech Kidizoom Action Cam Battery Replacement: 7 단계, 이미지 1/3 VTech Kidizoom Action Cam Battery Replacement: 7 단계, 이미지 2/3 VTech Kidizoom Action Cam Battery Replacement: 7 단계, 이미지 3/3
    • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
    • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
  8. VTech Kidizoom Action Cam Battery Replacement, Battery: 8 단계, 이미지 1/2 VTech Kidizoom Action Cam Battery Replacement, Battery: 8 단계, 이미지 2/2
    • Use the soldering iron to unsolder the battery wires connected to the motherboard by reheating the existing solder.
    • Do not cut the two wires at the same time as this can result in shocks.
    • Soldering Iron will be very hot and can be dangerous to touch.
  9. VTech Kidizoom Action Cam Battery Replacement: 9 단계, 이미지 1/1
    • Gently lift the battery away from the motherboard using a plastic opening tool.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Ross Anderson
회원 가입일: 02/10/16
630 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-5, Sullivan Spring 2016 USF Tampa, Team 3-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G5
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Where will get new batteries for same.
Niketan Naik - 답글
Where does one buy a replacement battery? And what type of battery is it?
clemsontiger04 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 69
전체 시간: 7,244
